My audio and video are out of sync when I split an avi using virtual dub and and TMPenc. The second mpg also has the audio of the first one. I have tried to split the audio in vitual dub using the framenumbers, no luck.
Have saved both parts as a separate project and to batch encode. This way, the output file of both of them is the same (the first gets overriden by the second), so I am ending up with one mpeg file. I am doing something not right I guess, please help.
Have tried to use the wizard/batch function in TMPenc also. Have spent considerable time already, please help if you can. Thank you.
1. Have you noted where at in the original video your second file begins and ends.
2. Load the original video into Gold Wave.
3. Select the part of the Gold Wave chart where your second file begins and where it ends. Copy this section, create a new audio file with just this audio.
4. Go back to TMPGEnc. Load the second video file as input video, and your new audio file as input audio, Start encoding.
-- Voilá!Hello.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
audio/video out of sync
By gibsonpm in forum Video ConversionReplies: 4Last Post: 30th Jan 2010, 05:53 -
audio out of sync with video
By natty in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2008, 06:21
