im having 2 problems really....
im trying to rip a dvd to cvd with subtitles
i have ripped the movie to the HD and used dvd2avi to make a
d2v file and a wav file.
now i need to make a fake avi file using vfapi so i can use virtualdub
and vobsub to extract the subtitles and resize/frameserve
to the encoder i want to use.
the problem is that vfapi doesnt let me SEE the d2v file, i can only
see that i can open tpr files, i used to be able to see the d2v files,
but now i cant, so i cant open them.
the seconed problem is that i remember tring to do the same thing
once, and cce just whouldnt open the vdr file, i dont know why because
i dont have a problem frameserving regular avi files using the same
way - and yes i have tried renaming the vdr to avi.
im using cce 2.51 by the way
i hope you can help...
Results 1 to 1 of 1
HELL AINT A BAD PLACE TO BE
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
VFAPI Reader Batch convert?
By Totta in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 11:44 -
VFAPI and Windows 7 64 Bit
By JekhoOne in forum Video ConversionReplies: 3Last Post: 21st Apr 2010, 13:56 -
Unexpected issue with VFAPI Reader
By NotSoEasy in forum DVD RippingReplies: 6Last Post: 8th Feb 2008, 04:29 -
Is there VFAPI Alternative (For Windows Vista)?
By foochuck in forum DVD RippingReplies: 16Last Post: 4th Nov 2007, 19:02
