I have tried for a week now making a copy of Monty Python's the Holy Grail. Each try has produced an out of sync copy. Sometimes the sync is fine at the beginning of the movie but slips out in the middle of the movie. Sometimes it is out of sync all the way through.
I downloaded forty-two last night and began a trial with that program but I stopped it after 12 hours because who wants to wait 30 hours for a DVD that doesn't need to be reduced?
The video is 3.8 GB and the audio is 295 MB. Any help syncing would be very much appreciated. I have tried a multitude of methods that I have been reading on this forum and so far none has worked
for DVDs <4.3 GB, i have been successful in using OSeX to rip the elementary streams (video and audio) then putting those directly into Sizzle to create a DVD image.
the movies that i've been successful in backing up to DVD-R (without having to transcode) are:
• spiderman
• enough
• not another teen movie
• and a bunch of my daughter's disney/animated movies (ice age, lilo and stitch, etc.)
there shouldn't be any audio sync problems at all with this method since transcoding isn't needed.
depending on the speed of your system, it should take approximately 30 minutes for OSeX, 30 minutes for Sizzle and 20 or so minutes to burn (at 2x).
accurate transcoding (sans audio sync problems) naturally takes longer.
hope this helps...good luck. -
Thanks for the reply. I did try the "sizzle" method on "Holy Grail" it was out of sync in the middle of the movie. Thanks for the heads-up on the other movies. I own some of those but have not tried them yet.
https://www.videohelp.com/forum/viewtopic.php?t=138014
if it doesn't need reducing have you tried this method? works great.pants on, pants off, pants the floor.
I seek the grail - What file format to use to archive everything as?
By freeboot in forum Video ConversionReplies: 6Last Post: 14th Nov 2009, 20:35 -
Audio stubbornly out of sync...except when it doesn't want to be.
By koberulz in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2008, 02:38 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
Holy crap...blown firewire port
By zoobie in forum ComputerReplies: 14Last Post: 4th Sep 2007, 09:45 -
problem with Nehemiah in Holy Bible-KJV-Scourby 2007
By JohnnyBob in forum DVD RippingReplies: 2Last Post: 14th Aug 2007, 20:59
