  1. is ther away to strip the audio from a avi file and save itas mp2
    Mar 2002
    cleveland/cincinnati
    you can tri using virtual dub and save the audio as a va file then encode to a mp2 with some other encoding softare
  3. TMPGenc will load the avi - get out of the wizard, you then select the file then Audio only and select a destination file & encode.
    Panasonic DMR-ES45VS, keep those discs a burnin'
