I'm trying to make a DVD from a Divx file - is this possible to do and if so, which program(s) do you recommend using for this?
I've tried ffmpeg but I can't get the audio to work though the video looks great. I tried both the QT and mplayer encoders without any luck. One thing I didn't do with ffmpeg is click on 4:3 pulldown - should I have done that to get the audio to work? Any help is greatly appreciated!!
you should be able to use a quick (dvd) preset in ffmpegX.
If it doesn't work (this might seem dumb), use Divx doctor to make a quicktime .mov first.
Burn the resulting dvd folder using toast.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
