im trying to take the audio off an avi.file using virtualdub, some work fine others however give me the following fault 'ACM failed to suggest audio decommpression format' this is followed by 'AVIOutputWAV:the handle is invalid' i never had this problem before ,any help would be appreciated.
Some AVIs have audio like AC3 that plain virtualdub doesn't like sometimes.
Try direct streat and save to wav to see if you can take the audio off into a file. Or try the VirtualdubMPEG2AC3 version.Panasonic DMR-ES45VS, keep those discs a burnin' -
ive just used a tool called avicodec which told me the files are 'ac3 dvm' ive looked for the virtualdub ac3 version but am unable to find it? is there a specific version or is it a patch,there also is a problem with it starting to save the wav.file then stopping.
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 15:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
re: virtualDub
By merlie in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 14:50
