  1. I have a movie i want to put on a cd to watch in my dvd player, but when i burn it (it is small enough to fit on one cd) the movie gets halfway done and the audio stops. The video is ok. I was using vcd easy to burn it, it did say it needed autopadding? and it had a bad packet, when i play the video on the comp everything is fine; audio and video both work. Is there anyway to fix the bad packet? or to autopad it ? so i can have audio on the whole cd.
    What is autopadding?
    Any info would be greatly appreciated Thanks
  2. <link removed - no warez>
    SIMPLE AVI(DIVX) TO VCD/SVCD/DVD CONVERTING GUIDES
    TAKES YOU STEP BY STEP AND TELLS YOU THE SOFTWARE YOU NEED TO COMPLEATE THE SAID TASKS
    MANY THANKS
    DIDIDDAVE
  3. The file is already in .mpg I went and converted it again using tmpge (i don't think it really did anything) but just in case. It isn't that the audio is out of sync it is fine then it just stops but the video is all there
