Hi,
I have created a DVD on my computer saved in Spruce Up, but i accidently used NTSC in the 'preferences' instead of PAL. Now i want to change it to PAL, can this be done? I dont want to start again as i dont have the time to re-import it again.
John
use ifoedit to change, open movie ifo, then click on lower
screen video attributes, and change...always check...
also, sometimes spruce-up messes up and leaves
video at 4x3, when its really w/s at 16x9, you can
change it there also, check against "ripped one"
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
How to change NTSC to PAL in adobe premiere elements 7
By jarko in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2009, 20:28 -
Change from PAL to NTSC DVD LG DR-4800
By mairel in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Jul 2009, 13:40 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
