I recently copied a movie onto my hard disk (used dvd decryptor), then used dvd2one to process the movie to fit on a single DVD , then ran IFOEDIT to 'get the sectors' and finally used Nero to burn the new movie.
My question is that I have managed to region zero the movie, but how do you change it's format to PAL from NTSC. The original film was NTSC and when it was played back on an old TV it played in Black & White! Yet on another newer TV it's in colour. At what stage do I change it, if I can ?
Also I noticed a lot of people talk of putting an empty AUDIO_TS folder when burning, well I don't and everything seems to work fine. What's the importance of buring this empty folder ?
I have the Pioneer 105 and home DVD player is the Sony 900V. I found the Balkpaq Gen 4 2xspeed disks although work on the pioneer , playback too, they just simply refuse to play (even when recorded at single speed)on the Sony DVD player and most other players I have tried. The Gen 3 1xspeed ones always work a treat and are cheaper ! Very strange. The GEN4 disks just seem completely incompatible with most DVD players out there.
well, the player showing black and white, sounds like it's hooked up to a PAL only TV. most TV's are PAL and NTSC compatible these days, but old ones aren't. simply change your TV type in the DVD setup menu from "Auto" to "PAL" and your DVD player will convert it on the fly.
Originally Posted by flaninacupboard
Not sure if it belongs here but need some advice on PAL/NTSC conversion
By HmNtr in forum DVD RippingReplies: 16Last Post: 29th Aug 2010, 10:48 -
Question about PAL & NTSC ripping and re-authoring
By Jack_Dante in forum DVD RippingReplies: 6Last Post: 23rd Mar 2010, 13:39 -
Question Re IVTC, DGIndex & NTSC Source
By onesikgypo in forum Video ConversionReplies: 7Last Post: 18th Aug 2009, 03:58 -
PAL to NTSC conversions advice please !
By beammeup in forum Video ConversionReplies: 4Last Post: 21st Mar 2009, 22:11 -
FAVC 1.04..Please Advice..Every time I convert PAL to NTSC
By sandman423 in forum Video ConversionReplies: 6Last Post: 3rd Jan 2008, 21:21
