I read about capturing, and at some point it is said that you're hard drive must be set to DMA... How should I do that ???
DMA is direct Memory Access.. to check to make sure yours is turned on follow these steps:
R-click MY COMPUTER
L-click PROPERTIES
Click the device manager tab
click the plus next to DISK DRIVES
D-click your hard drive
click on the SETTINGS tab
verify you have check mark in DMA
IF NOT:
put check mark in, click OKAY
Click OKAY and restart your computer...
When back to desktop, verify the check is still in DMA and now you know your dma is set (should be always, its faster)..
IF THE CHECK IS NOT THERE:
Your hard drive is not dma compliant, and I would really suggest you buy a new hard drive, because your hard drive is way behind the times....(And slooooow)
NOTE: Verify DMA is also set on your cd-roms, they too have dma capabilities...
Hope that helps...
-=> M.C.P. ICE Logix <=-
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 11:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 15:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 14:15 -
DMA PIO Reg Prob Key Deleted returns after reboot
By tonib95 in forum ComputerReplies: 14Last Post: 4th Feb 2008, 11:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 23:35
