When I try to burn a DVDR disc on my (Dell) NEC-1100A drive using
Nero, it sees it as a 2.4X speed drive and won't let me change it to
1X. It is grayed out.
Do I have something set somewhere else to cause this? Or is it a hardware limitation?
Thanks,
Dignan
The base speed of DVD+R/+RW is 2.4x so I don't think you can go lower than that.
Why do you want to lower the speed for? -
I want the lower speed because I just purchased 50 Riteck 2X dvdrs.
I bought them from shop4tech as was recommended in teh media forum. What are the chances they take these back? I'd like to exchange them for 25 4Xs.
What should I tell them? It seems that they will charge a restocking fee and shipping if the wrong item was ordered instead of the wrong items sent(at best)
Anyone want buy 50 Ritek dvdr's at a $10 discount?
Holy crap. I just realized even if they were 4Xs I still be screwed.
It appears my NEC 1100A drive will only burn DVD + Rs.
Yikes!
What is the deal with Dell anyway. They don't provide documentation with their new machines?
Oh well. -
Dignan,
Can't you exchange the discs you bought for DVD+R/+RW discs? It was an honest mistake on your part, I sure hope they will let you exchange it.
If they won't, maybe you can sell it to someone who owns a DVD-R/-RW drive.
Gil
EasyCAP only playing the video, not allowing me to save it
By denadel in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2009, 09:48 -
I keep getting write errors in Nero - help :(
By Akhet in forum ComputerReplies: 11Last Post: 30th Oct 2009, 14:51 -
SHW-160P6S can't write DVD-R disks using nero 6
By kwgpc in forum DVD & Blu-ray WritersReplies: 11Last Post: 8th Sep 2008, 11:02 -
Google Sites Not allowing Embedded scripts.
By freebird73717 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2008, 13:16
