Please forgive me if this has been asked already but I cannot find it anywhere. I understand that to burn a DVD-R with RecordMax, one needs to select the "Data" option and that you have to put your already prepared VIDEO_TS, AUDIO_TS folders in the "add file/folder" section.
Can anyone tell me what should be the other settings under "Options"?
What are the recommended settings to have compliant DVD-R for playing on standalone DVD players?
"Track at once closed vs not closed"
"UDF with Joliet-up to 106 in length, any char., plus joliet, plus 8+3 tree(Bridge)"
versus
UDF- up to 128 in filename length, any char., plus 8+3 tree (Bridge)"
What about "primary volume descriptor fields"?
I am trying to make the switch from NERO to RecordMax as I keep hearing good things about it for DVD recording.
Thanks for your input,
no bbcode in subjects - it doesn't work - moderator
"Track at once closed"
I "think".I don't have a bad attitude...
Life has a bad attitude!
[Encore CS4] How use max space of DVD
By darkztk in forum Authoring (DVD)Replies: 2Last Post: 6th Jun 2010, 03:23 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Max DivX quality in DVD player, please!
By zovx in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Feb 2010, 13:43 -
how to achieve max quality in fairuse wizard, x264 settings
By llmercll in forum Video ConversionReplies: 21Last Post: 17th Jan 2009, 09:17 -
60 Inch DLP Max 1080i Settings ??
By ofield1 in forum DVB / IPTVReplies: 12Last Post: 29th Feb 2008, 19:54
