  1. I just finished burning a dvd produced by Maestro. It is freezing or pausing for a split second between all the chapter points. I usually use spruceup for my authoring but thought I would give Maestro a shot. I made all the chapter points at the nearest gop. Any idea what is causing the pause? I have never had this issue with any other authoring sw.
  2. in connections you have probably set the action for the end of each chapter to start the next chapter - this is why it is pausing. Remove those connections.
  3. You are absolutly correct furball. I did have them set that way. I was under the impression that I had to set them that way. I guess I will have to go make the adjustment. Thanks for the speedy response bud!
