I'm encountering problems with dvd2one...
I pop the DVD in a player and it shows one second clips of about 5 chapters and then freezes. It does this with several different movies and also with several different burn apps (NERO and Recordnowmax).
I rip with DVD decryptor, encode with DVD2ONE and then burn with NERO or recordnow with the same problem every time.
HELP!!!!
thx.
I'll try it. Why does DVD2ONE (or DVD Decryptor) not do it?
(It seems like everyone else avoids that problem...)
thx for the tip. -
go shopping with you dvd you madde... I mean... check to see if your dvd player is flawed.. test your dvd's on different dvd players in best buy or circuit city... if it plays fine in any of those dvd players... buy one! 8)
Burn works fine when played on PC, but not on my stand-alone player (Sony)... sheesh.
I also experiencing the same problem....my DVDRs will only play on my APEX 1500 DVD player which has macrovision and regions removed. The recorded DVDs wont play on Toshiba SD1200 and Apex 1200. I use DVD Decrypter, DVD2One and then RecordNowMax. Anyone have any ideas how I can make this playable on other DVD players. Thanks in advance
I've been using the DEMO version of DVD2ONE...
my standalone player is clearly trying to "read" chapters beyond the 30 minutes that the demo encodes. Could this be the problem?
Has anyone had this difficulty with the demo, but then resolved it with the full version?
thx.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
