Hello,
I managed to get an mpg-2 (SVCD) file with two audio tracks
(german and English). Now i want to cut it into two halfs to fit on 2 CD's.
But when i use TMPGEnc (Cut&Merge) i loose the second track
I allready tried to cut the second audio file before multiplexing it,
but then i get out of sync on the second CD.
What's the trick here ? Do i have to use a different tool or do i miss
some options ?
Grady
TMPGenc is a horrible mpeg2 cutter. Use bbmpeg instead.
Encode each stream separately, so that you have 1 video track and 2 audio tracks. Then you use BBmpeg to multiplex and set a cut point. There is a guide on this site for it. I guarantee its the best way to cut mpeg2 in general, and definitely the best way to do it with multiple audio tracks.
If you don't have all the streams separate, then you can use TMPGenc's demultiplex (not simple demultiplex) to get each stream.
Make sure you get the latest version of bbmpeg, 1.24. -
Well, .... smart as i am
i manged to find a way around that prob, still using tmpgenc.
I simply created two "big" files, one with german audio, one with english.
Then i cutted both files into two equal halfs (same timestamps).
After that I demuxed the english audio from the english halfs and muxed it onto the german
halfs. This is working fine, without any lip sync probs.
Still trying to find and easier, faster way,
Grady
PS: (SmartRipper -> dvd2avi --- BeSweet -> TMPGEnc) that's it. -
If you want a faster and easier way then use bbmpeg like I said. You just encode all your streams separately, its faster that way anyway. Then you load them all and multiplex and cut at the same time.
Split mp3 into pieces for an audio cd
By andrekb in forum Newbie / General discussionsReplies: 6Last Post: 12th Mar 2012, 21:25 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Hi all, I need program to batch de-multiplex mpg files with 2 audio tracks
By mmdmmd in forum AudioReplies: 4Last Post: 14th Oct 2008, 15:57 -
Cutting a MPG FILE
By peekayem in forum EditingReplies: 3Last Post: 16th Mar 2008, 09:06 -
Audio - split into pieces
By kj1983 in forum AudioReplies: 3Last Post: 11th Jul 2007, 16:37
