I used TMPGE to make a DVD NTSC. Once TMPGE finish, I have a M2V video and a Wave- pcm file. I can not get Ulead Movie factory to author or IfoEdit to remux. What do I need to do to Author/burn?Please, give me a little detail.
With Ifoedit you want to author new DVD. Why not use an .mp2 or mpa instaed of an uncompressed wav file. And save the extra space for the video? I use TMPGEnc to encode as MPEG 2 then I demux it for Ifoedit.
I do believe Ulead movie factory wants an MPEG 2 already muxed together. So when I use Ulead. I just input MPEG 2 and then make chapters and menus.May the force be with you. -
Tbear is correct, Ulead wants an MPG to author, not the seperate m2v + audio files (like most other authoring programs, eg. Maestro). However, you should be able to author a m2v and PCM file with IFOEdit.
Take a look at:
https://www.videohelp.com/forum/userguides/120013.php -
I remux my M2V & wave file with IfoEdit, but the audio is off from the video.
What can I do to fix this and what cause this? was it the setting the TMPGE for DVD? Oh, think you for the help, guys/girls.
Reduction of a wave file from 35 MB to 24 MB How?
By andy jackson in forum AudioReplies: 4Last Post: 1st Jun 2011, 11:41 -
Tsunami Wave on it's way here!
By budz in forum Off topicReplies: 20Last Post: 1st Mar 2010, 11:23 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 00:05 -
Wave Metadata
By loster in forum AudioReplies: 0Last Post: 1st Sep 2007, 09:45
