Hey, is there such thing a a 600 and a 600A or are they the same thing? Also can the 600/600A be macrovision/RCE/region free without physicaly changing the chip? (i.e. updates burned to a cd and upgrade that way)
If people can reply to this that would be aswome! Stay Tribal!
The first AD600A models had a 'secert menu' that would could access to change the region and turn off macrovision (and CCS). Current models have a newer firmwire that 'fixed this defect'
If you are looking for a moddable Apex, the 500W is your best bet. The modchips (I'm told) are easy to install and do not require soldering. -
What's better the 500 or 600? Is picture the same? Thanks 4 replying!
i have the 600a model. do you know how to get to the secret menu? or where i can find info on it? that would definatly make my day. thanks.....
nevermind. i found it. it does work. but now i just have to figure out how to route my sound into the vcr and into my sterio reciever. got to keep at least dolby digital if i ever use my dvd player thru my vcr.. thanks for the hint
Vejita-sama -
On 2001-09-05 17:20:26, Boaz wrote:
Hey, is there such thing a a 600 and a 600A or are they the same thing? </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
There's only a 600A -- no 600.
The Apex 660, if you can still find one, can be modified via CD (except for the early versions of the player -- which hopefully are no longer available -- those require a chip replacement, like the 500W). The 660 is about USD $120 at Sam's Club while the 500W is USD $98.86. If you buy a 500W, you'll have to spend at least USD $15 on a mod chip, so the price becomes about the same as a 660. Plus the 660 has much better MP3 support and can play raw MPEG files (i.e., you don't have to burn them as a VCD first.)
TRV-330 > DPS-220 (tbc) > TV Wonder 600 Pcie S-Video Question
By Frank_aspen in forum Capturing and VCRReplies: 8Last Post: 1st Mar 2012, 20:15 -
TV Wonder 600 and TV Wonder HD 600, is there any real difference?
By jedi55 in forum Capturing and VCRReplies: 3Last Post: 20th Mar 2011, 22:53 -
WHICH LAPTOP for around $600
By blinky88 in forum ComputerReplies: 16Last Post: 18th Mar 2011, 04:23 -
Biostek XS-600 help
By binkx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Oct 2008, 09:46 -
Which Camcorder under $600
By chesnex in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st Oct 2007, 04:32
