I have converted a number of xvid files in the passed and they work (had problems with some), but the last three files (different films) have had a perfect picture but no sound. I have tried extracting using Goldwave and virtual dub, but it still does not work.
Also removed NIMO and XVID and re-installed xvid version XviD-04102002-1 but still no sound.
Can anybody help.
Need more information if I am to help. What are you encoding to? What programs are you using for converting and/or authoring? What type of compression does the audio have? Most likely it has AC3 audio and you need to search the forum to find how to deal with it.
Thanks for that I have done a little more checking...
I get no sound when I play it through windows windows media player. I have checked using Gspot and it is AC3 format. I will have a look at the forum and see how to deal with it. -
I had the similar problem when converted some xvid avi files to mpg. I finally solved the problem and came out a step-by-step guide. Hope it can help you.
https://www.videohelp.com/forum/userguides/140703.php
How do I reduce sound channels from 5 to 2 on my xvid file?
By aqueousdan in forum AudioReplies: 6Last Post: 5th Jun 2010, 13:22 -
Xvid has no sound DVD architect 5.0
By corl45 in forum Authoring (DVD)Replies: 8Last Post: 26th Jun 2009, 13:58 -
samsung dvd-p171: bad sound with xvid?
By pengocha in forum DVD & Blu-ray PlayersReplies: 11Last Post: 10th Sep 2008, 13:09 -
Sound Problem During Playback (XVid, DVIX etc.)
By Pyrolisk in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 11:00 -
FairuseWizard2.6 & Xvid = Horrible Sound.
By avdw in forum DVD RippingReplies: 2Last Post: 21st Sep 2007, 13:33
