Hi,
just wrote my first DVD from a downloaded series episode, the disc wrote perfect and play perfect on my Stand Alone player BUT is not playing on the DVD Burner? The burner is a CenDyne (Pioneer 105, latest firmware was already installed).
Anyone know anything about this??
Patrick
is this a princo dvd-rw? they do that on my setup too (dvr-105).
i've heard of a couple of similar cases. there's an odd chance that the burned media will read on the burner, but that's just an odd chance. almost all the time i get a verification failure on nero, but the disc plays well on the standalone and on a regular dvd-rom drive. -
Not sure what type the media was, came with the writer, after second write Nero told me it was not a rewritable and would not erase it. I got a couple of Memorex ReWritables today and they work fine.
Funny thing I have found is that here on the site it says my Stand Alone DVD player JVC XV-S300BK cannot play DVD -RW disks but I have used them and they have palyed perfect for me.
So far I have used DVD -r Maxell and DVD -RW Memorex and have had only one coaster due to user error.
All in all writer seems to work exceedingly well.
Patrick -
Originally Posted by crowdx38
Hmm... Well it is interesting. This post is almost 2 months old but I just tripped over the same set of events and finally figured it out.
The drive is a Cendyne 4x (a Pioneer DVDR105 re-badged) and the media that came with it is a single white faced re-writable. After writing out a converted DVD to the disk it is no longer recognised in the DVDR drive. And if you try to erase it with Nero Express it complains that it is not a re-writable disk any longer.
The computer is running WinXP Pro SP1 and completely updated from MS website.
To solve this issue I had to reboot the PC after the burn session and then use Nero Express to do a "Quick Erase" on the disk. After the Quick erase session (which lasts about 2 min.) the disk can be Fully Erased with the Nero utility.
During the confusion I found the disk would play in any other DVDrom drive and worked well in my satnd alone players.
Sadly, WindosXP seems to have a problem with the either the drive or the media. My drive still has the original 1.21 firmware. I run into this problem if I burn from Pinnacle IC7 or from Nero Express. Probably true with other systems as well.
Still interesting to note the need to reboot.Only 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy
Sony Optiarc DVD RW Drive writes but verify errors???
By bahjan in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Jan 2012, 08:33 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 02:27 -
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 21:47 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 12:36 -
DVD drive no longer writes to DVD +R
By GAR in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Jul 2007, 20:43
