I used DVDDecripter to copy a DVD. When I write it says "disc not formated" and refused to to write.
I used DVD-ON DVD+RW media to write an image through Easy CD Creator. After the writing it automatically played OK. But When I eject the disc again it always says "blank disc" or "Please insert a disc". I tried serval times with the same result.
I tried MyDVD to create a very small DVD. It worked OK. However MyDVD can't write images.(?)
I also copied some CD with Easy CD Creator. The results are OK. But when I look at the properties of the CD it always says "0 bites used".
Huaien
well try formating your dvds. i had that problem on some +rw's. but once it was formatted it worked fine. should be able to use Easy CD Creator to format them.
No shit? You can format DVDs in Easy CD Creator? I had no idea.
Darryl -
well i am not sure i never liked the program myself. seems to me if you are able to burn them you should be able to format them.
try using Nero program. It has a demo version in this site.
https://www.videohelp.com/tools
good luck!!! -
Thank you all.
I tried formating the disc with Easy CD Creator. And wrote it on the disc. But my NEC ND1100a didn't recognize it.
I wanted to try Nero. However the file created by DVDDecripter is an Easy CD Creator image file. Nero doesn't support it.
By the way, when I tried to create an image with Ifoedit, it says " can not locate the imglib.dll. Where can get the Imglib.DLL? -
The IFOEdit Img Tools can be d/loaded from http://www.doom9.org You can either run these programs (image maker and burner) from within IFOEdit or as standalone programs.
