hello. i hope this is the right forum...
I have a dvd (pulled from usenet) that will not play on my set-top or PowerDVD. the individual vob files are in fine shape (viewed them with powerdvd) and i believe it has to do with the ifo files.
what i'm looking to do is use the vob files in some program to recreate the needed file ifo/bup files so that when i burn my VIDEO_TS folder the movie will play. the dvd is the movie only, no menus, etc.
any help would be appreciated. if this for some reason belongs in the ripping forum i apologize. figured since i'm looking to author a dvd from existing files this forum was a better fit (no ripping, copying, etc being done here)
thank you.
Go to www.ifoedit.com and read the guides. They will show you how to create new ifos. Ifoedit.exe and vobedit.exe are no longer on the site , you will need to get them from another site like vcdhelp.
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 01:31 -
cant open wmv files. have read previous forums.
By UmmAddan in forum Newbie / General discussionsReplies: 9Last Post: 29th Dec 2009, 13:49 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31 -
authoring dvd using a group of vob files
By sumeshkri in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2008, 11:23 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
