  1. hi,
    i hav nero 5.5.6.4 s/w burner for my HP cd-writer plus (16x).
    at first i made an svcd without the scandata.dat file, my dvd player (philips Q50 firmware ver 1.45v) was doing a track change when scanforward was pressed, then i downloaded the scandata.dat from this site but still the problem remains.
    now i wish to try and make a bin file using vcdimager or vcdeasy and burn the bin file, using nero, but i heard that nero has a problem burning bin and cue files, is it correct ? Has any1 tried it.
    pls respond.
  2. I have over 140 movies that have been burned using nero's bin/que (burn image from file ->burn image) setting WITHOUT a problem. Recommend burning at a slow speed.
  3. hi, thanks for replying. which version of nero do u use ?
    thanks again.
    Mar 2002
    United States of America
    I use version 5.5.9.17 of Nero. :P
