Hi there you lot
ok this is a basic question???
does anyone know how to remove bad frames from an .avi file so the compressor (virtualdub) does not give this error...if anyone can help it would be a MASSIVE help
this is using Virtual dub
i am trying to put 2 cd videos on to 1 cd to save space
i decompress the audio and save as .wav
then add avi then avi segment
then load the audio in and set up the full prossessing mode to 128 kbps CBR lame mp3
then sett up the video full prossessing mode sett compression to Xvid codec and the KBPS that the Calculator said
then save as avi
25% of the way though i gett this
i have tried to use the scan video for error then its masks the bad frames then i save avi again but i still get the error,
if i mask the frame manually how do i find out which frames are good and which are bad. i have used DIVXFIX and AVIFIX But they dont delete the frames just the HEADER
i get this on vertualdub and nandub can anyone help me please
thanks in advance![]()
Results 1 to 1 of 1
XviD4PSP Re-Encoding Error?
By Kid Ryan in forum Video ConversionReplies: 1Last Post: 26th Apr 2011, 04:07 -
encoding error...
By rkane in forum ffmpegX general discussionReplies: 6Last Post: 2nd Oct 2010, 01:45 -
Error when encoding
By edgarfrito in forum ffmpegX general discussionReplies: 1Last Post: 2nd Sep 2010, 00:55 -
Keep Getting an Error when Encoding
By kee2987 in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2010, 12:45 -
Two Pass encoding error
By iSherbiny in forum EditingReplies: 0Last Post: 10th Jan 2010, 07:14
