  1. Hi all,
    I am trying to shrink down some Star Trek TNG episodes so that 4 can fit onto one DVD-R. I am using TMPGEnc, but I keep getting this real annoying combing effect, best as I can describe. It only happens when something moves fast, like someone waving a hand and or grabbing something, it's really quite bad. At the leading edge of the movement it looks like some one has smeared the image with a comb.
    I am re-encoding at 3000 kb/s so I think my bitrate is fine. On slow or still moving scenes it looks great. Here are the rest of my TMPGEnc settings:
    -------- PAGE 1 ----------------
    Aspect Ratio: 4:3
    Frame Rate: 23.976 fps (internally 29.97)
    Rate Control Mode: Auto VBR at 300
    Profile &Level: Main Profile & Mainlevel
    Vid Format: NTSC
    Encode Mode: 3:2 pullodwn when playback
    YUV format: 4:2:0
    DC component precision: 8 bits
    Motion seach precision: High quality (slow)
    -------- PAGE 2 ----------------
    Video Source Type: Non-interlaced (progressive)
    Bottom field first (Field B)
    4:3 525 line (NTSC)
    nothing else is checked...
    The reason I have it at 4:3 and 720x480 is because that matches the original. Any help would be hugely appreciated thanks.
    rhuala
    Apr 2002
    The State of Frustration
    It is called Interlacing. First, try to use De-Interlacing.
    Hello.
  3. It is called Interlacing. First, try to use De-Interlacing.
    That's one of the first things I tried:
    Selected: Deinterlace (None)
    Also on page2 changed: Video source type to 'interlaced'
    Still looks like crap, very comby. Starting to get really worried here. I can't find any guides on this and am running out of ideas. I've done about 12 encodes with various settings over the last 3 days to no avail.... help
    rhuala
