Just received my first order of Ritek G03's from Rima.com, on the edge of the discs it looks like there is glue or something coming out of the middle of the disc. I also see this on my Taiyo Yuden's that I ordered from them.
Should I worry about this? DVDDecrypter reports the discs as Ritek G03 and Taiyo Yuden's.
The Riteks G03 I received from Shop4tech also dont have smooth edges. They looked like too much "purple" material was apply and extra "bubbles" of material dry on the edges.
The only labels on the package was "Made on taiwan"... The disk are silver/purple and the info on them is ok. So far they all burned and played perfectly. -
I've burned three so far and they all seem to play ok. Haven't watched them all the way through though. Hopefully they will be ok.
The Taiyo Yuden's really suprised me though when the edges weren't smooth on them either.
Anyone still buy from Rima?
By VDubMike in forum MediaReplies: 3Last Post: 11th Jan 2012, 22:21 -
Where Are these Ritek CD-Rs Made???
By NBK2 in forum MediaReplies: 19Last Post: 19th Aug 2010, 14:32 -
Cakeboxes from Rima are CRAP!!!
By videobread in forum MediaReplies: 13Last Post: 8th Nov 2008, 03:11 -
Buying DVD DL on Rima, need advice
By Thadius856 in forum MediaReplies: 1Last Post: 26th Jun 2008, 01:58 -
Ritek: NEVER EVER AGAIN
By mrlar2 in forum MediaReplies: 50Last Post: 15th Aug 2007, 04:13
