Does Anyone know something about the multiregion discs?
Can you be a bit clearer with your question, I don't really know what you mean. What multiregion discs ?
Sorry, But I just happen to hear about some discs that you just insert in your dvd player and install a kind of software that makes it multiregion. Something like the ones for the Dreamcast.
Sounds like you're asking: "How can I make my DVD player region free." Take a look to the left under DVD Hacks. Some standalones can be mae region free by hacking/updating the firmware, to do this you insert a CDR with the new firmware on it. I think this might be what you heard about. A lot of the low end players are actually PC DVD-ROM drives with an external case (eg. Apex).
Other players have loop menus you can access but hitting keys on the remote in a certain order (eg. cyberhome). -
Thanks For your advice but I donīt really know where can I find the new firmware for my DVD Player because in DVD Hacks I only find Menu loops and there is not one for my Kenwood DVR7000.
Can you help me with that?
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
How do I set a LG DVT499H into multiregion?
By ELCROWLEY in forum DVD & Blu-ray PlayersReplies: 2Last Post: 4th Aug 2009, 13:24 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
Multiregion code for LG DK7821P
By ieh4f in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2008, 16:11 -
multiregion hack
By chrissi34 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jun 2007, 17:59
