Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Page 1 of 17
1 2 3 11 ... LastLast
Results 1 to 30 of 498
  1. Finally Pinnacle InstantCopy 7 is available. There is a demo version in their site:
    http://www.pinnaclesys.com/ProductPage.asp?Product_ID=1153&Langue_ID=2&SID=199
    Antonio S.
  2. Any idea on pricing, or where to get it?
  3. Loosk like the british site. When you select where to find, it pops up with United Kingdom and only wanted the two first digits of a postal code.
    I have heard it avaiable in europe and if the news is true may be comming here.
    The demo is 14mb big!
  4. Sure is.
    I'm downloading it now. :bad-boy:
  5. Member tumbar's Avatar
    I am downloading also, they must be getting hammered,,,,the stream is down to a trickle.....
    anyone try it yet
    Jim
  6. I noticed this on the site, "... Make a true 1:1 copy of any non-copy protected DVD on a recordable DVD."
    I assume all dvd's release by major movies studios are non-copy protected.
    So, how does Instant Copy help us?
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    You remove the copy protection with dvd decrypter, smartripper and then you can use instantcopy to convert your dvd-9 one recordable dvd-5.
  8. Originally Posted by Baldrick
    Ahh, I see.
    So InstantCopy will process files already saved on my harddrive.
    I can't wait to get.
    Thanks,
    R.
  9. anyone know what the limits of the demo version are?
    RealaT Bytes, but that's what life is.
  10. Originally Posted by RealaT
    I just dl'ed it, but haven't tried it out yet. The demo is good for 15 days. But the AC3 audio is limited to 5 minutes.
    Netherlands
    Does it really copy 1:1 (including menu's etc.)?
  12. Clicked on the link to buy it, didn't see it available. Or is it one of those deals were you need to load a serial into the demo. Maybe it's too new so they don't have it listed yet.
  13. I'll have to DL this when I get home tonight. Anyone who has taken this in, can you comment whether it lets you downgrade the Extras to leave more room for the bit rat for the movie?
    Really I don't care as much for the extras as I would like an easy way to retain the Menu. Extras would be ok if they could be squeezed smaller. But then how much smaller could you go before they are unwatchable?
  14. I tried it out on Sweet Home Alabama. It took about 110 minutes to create a PDI file (I guess that stands for Pinnacle Disc Image, or something like that). The movie itself is 109 minutes + about 20 minutes of extras (7.8GB). The final file was 4.38GB. I think it's about 300MB short, because the demo only does 5 minutes of AC3 audio. I'm burning it to a DVD-RW right now.
  15. Reverenddave can you tell us how good is it does it look like the real DVD how long does it take to encode? Thanks
  16. Rev, does it let you adjust the size of the extras? Or is it 1:1 copy there as well? Does the menu work exactly like the Original? And of course yes how does it look? Maybe you could do a copy with DVD2one and Compare the two.
  17. downloading this bad boy right now. Can't wait to try it out
  18. The total time to go from DVD-9 to DVD-R was about 3.5 hours. 45 mins to rip (DVDDecrypter), 110 mins to shrink the files and 55 mins to burn (1x speed).
    I didn't see any way to adjust the size of the extras, but maybe I was looking in the wrong place. There's an option to remove DVD-Rom features, remove audio streams, remove subtitles and remove User Prohibitions.
    The menu works exactly like the original, so as far as that goes, it's a perfect copy. I'm not a good judge on video quality. To me it looked fine, but I just spot checked the disc. The AC-3 audio ran the entire movie, so I'm not sure what they meant by a 5 minute limit.
  19. so just use decryptor and select all files? Then this little program? hmm, gotta check this out once it finishes. Geez 7 k/sec, site is popular
  20. Reverenddave what movie did you do was it NTSC or PAL? Thanks
  21. Reverenddave can you encode the same movie with DVD2one and post picture's you can take picture's with powerDVD also can you do a encode with DVD2DVD-R also and post all picture's
  22. Originally Posted by spiderman2k1
    Sorry, but I don't have time right now. I'm sure someone else will compare the 3 programs.
  23. Can you tell us what Movie you encode and was it NTSC or PAL THANk's
  24. Originally Posted by spiderman2k1
    Sweet Home Alabama - Region 1 NTSC
  25. Member
    Jan 2003
    New York, NY
    3.5 hours ???
    Sounds like DVD2one is still the right tool
  26. GenePool_ there is no right tool. Just tool that can do the job you want do not get me wrong I love DVD2ONE I really love DVD2ONE. But if InstantCopy can copy any DVD it's good for episode DVD like band of brother's and ANIME
  27. Member
    Munich, GERMANY
    I've made a detailed test report on this site:
    http://www.dvd-svcd-hilfe.de/forum/mb1/instantcopy7/instant.htm
    At the moment it is german only (sorry !).
    But I'm currently working on an english translation which should be available on sunday or monday ...
    Meanwhile you can use a website translator (for a bad bad bad translation)
    regards
    mb1
  28. Anybody else with any info. on this..?
