http://pinnacle.custhelp.com/cgi-bin/pinnacle.cfg/php/enduser/std_adp.php?p_sid=OBUpfCC..
is that the oversize issue you are referring too above?
or is it the undersizing issue I am getting?
Results 391 to 420 of 498
MY HISTORY IN DVD....Instant copy is the only one program working in my dvd player...Dvdxcopy,dvd2one and sonic my dvd have failed...At the beginning i thinking is a media problem...My Atlantis land 2000e dvd player recognize the disk as dvd but running continuosly and the movie not start.I have tried with dvdxcopy,with dvd2one and sonic my dvd (with a movie created with tmpenc 2.59) the same result...I have tried with Instant copy 7 source hd, destination sony dru500a with the same media (a that's write dvd 2x), i have lowered the quality of extra with registry key and the result is great!The only difference is the write speed (medium for instant copy,but i don't say if "medium" is 1x or 2x-2x for the other).All work fine!!!the dvd created with dvdxcopy working bad with sony dvd player of my friends (the disk running continuosly and the menu start randomly but in very rare case...),but the same movie created with dvd2one (all with that's write 2x media) working fine...I think not exist the best program or media for create a compatible dvd,but everyone have to find the program the media and the system for his home dvd player...
is that my previous post making this thread 3 foot wide?
If you me me MackemX there was a link to a review in German in this thread around page 3 to 6 that if my old college German and Babbelfish were correct that they know of a under problem. But no word on when it will be corrected.
Some of the problem listed on ther help board have never seen. -
good news again on my 8 % theory as I've completed Disc 2 of Back To The Future
only 48MB shy of the 4489MB barrier when IC had finished with it as I used 7.5% instead of 8%, would have only been 27MB if I had used 8%
I'm gonna post more info in the link to the post above
I'm gonna try a different disc now -
Originally Posted by hymes
If on the other hand the IFOEdit DVD player tells you that it also played something like Titleset 5 (which may be something like a logo or a Dolby Digital trailer) then for navigation your player will expect to see Titleset 5 before it plays the main movie, so you will need to keep Titlesets 1 and 5 and could remove the others. Similarly you can expand on this and check the titlesets for any other options you wish to keep, e.g. Chapter menus which have been known to occasionally use a separate titleset for the transition between menu and the scene selected. -
having done a few more test with instant copy, I've come to this conclusion.
the quality is very good, however it's so damn slow that, for me at least,
is only worthwhile for DVDs that have mulitple episodes like the sopranos
or band of brothers, etc.
For everything else I'll stick to dvdone or my hand rolled CCE encodes.
-d -
Originally Posted by dc91gt
Or some people might think that subconsiously I spotted the difference :P
Also, so far I haven't had single problem with DVD2ONE whereas I couldn't get PIC to do Spartacus, it kept crashing on the analysis stage. Spartacus is just over 3 hours and DVD2ONE did it in 20 minutes which I think is bloody awesome.
However, I'm still keeping an open mind, and I will persevere with more testing of PIC as I do prefer to keep most of the DVD structure/extras and I like the way you can reduce the quality of them to give more to the main movie. -
since everyone else seems to be putting their view of ic7 and dvd2one on here, here's mine:
i like menues, i like the extras (except for trailers for other movies) and ic7 is the easiest way for me to go.
and a 7.x gig 2 layer disk, from start of rip to end of writing is only about 3.5 hours for me. since i have 3 computers, leaving one run to do this is nothing to me. that and i can get homework done. -
After running out of the trial period here are the bugs I found:
- navigational errors
On some DVD's Intant Copy messes the navigation. Mainly when you want to go back to the main menu the playback freezes on both set-top and pc player. It even happens when no titles were removed, just the whole DVD was copied and automatically resized. From my experiences it couldn't be even solved with post - IFOUpdate & IFOEdit editing of the new IC7 files befoire burning them. The navigation must by messed directly in the VOB navigational streams which you can not fix with IFOUpdate & IFOEdit.
- For some strange reason the newly PIC7 transoced DVD has got different main menu format. On the original disc the main menu was in 16:9, now it is 4:3 pan-scan which hides some text. This happened on Fellowship Of The Rings 4 DVD version when copying any of the discs. Even when I tried different options when copying the menu.
Had someone the same experiences? -
Like others, I have problems keeping subtitles. I've tried two movies so far and no-go.
I've examined one DVD-R with Subrip. On the main movie, the subtitles are indeed Dutch.
On the extra's however, they are German, while the language indicated is still Nederlands (that is Dutch)......
However, when playing back this disc with my stand-alone (Toshiba) DVD player I do not see any of the subtitles. Also on my PC with PowerDVD XP, no subtitles are shown. On both, the available lanuages subtitles ARE correctly shown (i.e. when I press the subtitle button I get the language indications), but when I select one, nothing appears on screen.... -
you probably need to remap the subtitles as you do with the audio when u strip them out
how you do it I don't know, but I know howto remap audio so I wonder if subs will be as easy to remap
ignore me if this isnt the problem -
Originally Posted by MackemX
Do you mean that this could be a result of the "registry hack" ?
So if I use it without the hack it would be OK ? Worth a try, let me change is back and give it a go...
I'll let you know... -
Originally Posted by LeveL_42
so outta say 6 audio you strip 2,4 then the following happens to the streams
1=1
2=3
3=5
4=6
5=doesnt exist
6=doesnt exist
I stripped tracks 2&3 from 4 audio streams with Simpsons and then track 4 became track 2, so when I selected track 4 in the audio menu the audio played was defaulted to play track 1 as there is no track4, so I change the mapping of track 2 within ifoedit to play track 2 when track 4 was selected
I assume the subs may have the same effect, can anyone confirm this? -
Using the full version with the hack, I haven't had any problems copying three discs.
The only change I've made is to strip out the French on all three discs.I don't have a bad attitude...
Life has a bad attitude! -
I still have the SID error when the program checks the video at the beginning. Is this a bug? Ripping w/DVD Decrypter in ISO mode, then mounting w/Daemon tools does not seem to help either...
Originally Posted by Timoleon
32bit and it will work fine.
puddy -
I got a email today from Computers4Sure stating they shipped my order for IC7...? Anybody else or anybody hear anything?
I ordered from J&R Music World on 16 Feb 03, order was shipped on 20 Feb 03 and I received it on 24 Feb 03, I work overseas so for me that was great service. Instant COpy 7 works great. www.JandR.com
Bud -
Does anyone know if Instant Copy is capable of doing batch jobs? I would love to find a way to process a ripped DVD and then have it automatically start processing another without any intervention.
I've tested it and it works ! Luckely subtitles don't take up too much space, but on the disc I tried there were about 20 or so languages so it is still a waiste of space, space you could better use for some extra quality.
We'll have to wait for Pinnacle (or should we say VOB) to repair this.
I wonder if it would also work if you keep all subtitles UPTO and INCLUDING the one you want and deleting the others.
I will give this a test, but looking at what Toolman2k says, it won't work either.
Another possible work-around might be using IfoEdit on the finished files ?
I have tried some things with IfoEdit before but not this, no idea how to do this.....I'm not a real expert, that's why I like IC7 so much!
Originally Posted by LeveL_42 -
Originally Posted by toolman2k
I'm sure this will be fixed in an update, shouldn't be too difficult to do I guess (Just renumbering the ID's I think....but again, I'm not an expert)
Do everything you would do the original way regarding stripping and rebuilding apsrt from the resencoding bit
then just stick it into IC and it gives excellent results
agreed IC is not user friendly when it comes to the stripping part but for the sake of 10-20mins prep with Ifoedit, it saves you a lot more work trying to retain the original DVD structure the 'TRADITIONAL' way (especially toughies)
when will people realise IC is NOT the complete ONE BUTTON PRESS product as of yet and is marketed as a 1:1 compression tool (probably never will be OBP and there will probably never be any other tool that works everytime either, due to the complex nature of some DVD structures), but is one helluva tool when it comes to fitting more than 4.37Gb onto a blank DVD
but use this tool after using ifoedit correctly (not just pressing delete playback!, but using MENU/VOB extras button) to strip the files and it is the best tool you can have to compress a DVD over 4.37Gb and maintain the original DVD structure!
as for audio and subs remapping, a few clicks in ifoedit sorts this problem out as all you do is create 'phantom' streams for the ones AFTER using IC and remap them
The only problem that I can say about IC is the missing 300MB but this can be accounted for by oversizing then pressing F5 to bypass the 4.32Gb limit
and if you are either still too small or too big then have a read of my suggestions here
www.deano.dsl.pipex.com/2big.htm
I feel people who refuse to use IC due to it's lack of ONE BUTTON PRESS, mustn't agree that it saves a lot of legwork when it comes to wanting to keep menu's & extras and probably dont use it to it's full potential alongside Ifoedit
your loss I say -
Originally Posted by puddy
) came out absolutely perfect. The quality is very high. Took about 4 hours --- converted the pdi files on the hard disk over to an iso and burned with Nero. Kudos to Pinnacle!!
A good update for IC would be to include a DVD playback testing option before burning and maybe this is possible if they added to the preview function, something a bit like ULEAD DVD WORKSHOP's button preview function or give the extra option of producing either a normal ISO image or a VIDEO_TS folder -
I've used InstantCopy to make 3 VCDs so far. With each one of them, the video and audio go out sync after about 20 minutes of playing. Has anyone else found this problem? I have no such problems with making DVDs.
~JayMan2~ -
I felt pretty confident that an iso burnt with the latest Nero would be OK, so I wanted to verify that IC7 had transcoded the whole thing properly. I was a little hesitant to use IC7 itself for the burning until I felt that it had done all the other stuff right.
Tonight, though, I'm going to give "City By The Sea" a try, and I'll set up IC7 for the burn as well. ...let you know how it goes.
By the way, the pdi utility programs that have popped up in the last week or two seem very nice!
