I am pretty new into the DVD world and would like to copy some of my DVDs to CD.
What is considered to ge a good and reliable software package to do this with ?
Pete
Results 1 to 12 of 12
i use "dvdcopy plus" to convert my dvd to vcd but this is my personal choice
have fun with whatever you use -
Don't use a software package (at least not at first). Rip with SmartRipper or DVD Decrypter (look under TOOLS or DOOM9 for alternatives) to rip the DVD to HDD.
Then DVD2AVI to create a D2V and WAV that you open and encode in TMPGEnc.
Now, that are GUIs that do this for you, but when things start to go wrong (and it will, sooner or, highly unlikely, later), you won't have a clue if all you know is to insert the DVD and click on "Rip!"
It pays off in the end to do it the hard way first, then (if you feel like it) pick the package that suits you.
/Mats -
Thanks heaps for the help - at least this gives me a starting point.
Pete
Originally Posted by flt123 -
G'Day Mats,
So what you are saying is to use a number of apps to achieve the results ?
Pete
Originally Posted by mats.hogberg -
Originally Posted by pmoscatt
What are u trying to turn them into, VCD or SVCD or do u just want MPEG or AVI, U said u want to put them on CD but what format are u looking for, I would advise against a lot of crap, Thier is a learning curve with doing it the long way but I see it this way, everyone is using windows, so they are takning the easy way anyway so the same should go for everything, U buy a Game to play not to learn how to fix it, If you tell me some more about what u want to do i will give u a list of some super good software that will help and have an easy learning curve.
G'Day GandyMan,
Well.... being new to all this stuff any guidance will be a bonus to say the least - and thanks for your time in advance.
Ok... this is the plan. I number of mates have some good DVDs they own in which I would also like a copy of.
At the moment all I have is a CD burner and a DVD burner is in the future. In regards to what format I should burn them in, this is where I'm open to suggestions.
Hope this gives you a further idea what I'm trying to achieve here.
Pete -
Go here htt://entiendo.gotnet.net and it will show you the best way to make a vcd/svcd. It will guide you in steps (because I think it's best to control the process instead of using those GUI's that do it all in one step) of using dvd decryptor/smartripper, dvd2avi and tmpgenc.
OKay first what do u plan on playing them in, if your computer than SVCD is best, if your Standalone DVD player than u need to see what it supports before u waste disks. Just going buy what you say rightnow I would say DVD2SVCD is going to be your best bet, it will keep chapters and that is a great thing in itself. So look to see what your player supports or list it here and we will see what it does.
But here is a pge to read on DVD2SVCD http://www.doom9.org/mpg/dvd2svcd.htm
Any problem PM me and I will Help U if I can. -
It all depends on what you want to achieve. The easiest way to backup a DVD? Sure DVDx will do the work decently. Most of the times.
Do you want to learn how to do the best possible backup of any possible movie every time? Use separate, specialized programs, where you set the options to what you find best for your goal.
Take the stairs (and learn the building) or the elevator (and just get to the floor you want - if it doesn't stop between 2 floors)?
/Mats -
Hi dbecker,
Thanks for the link.... looks good.
Much appreciated !!
Pete
Originally Posted by GandyMan -
GandyMan,
Thanks heaps for the help.
I will be using them in a Home Theater DVD Player (Omni 3300) which is only new and supports all the usual formats including DVDR which is a bonus.
I would have thought using SVCD would have been the best option ??
Cheers Pete
Best current software for BD ripping
By rocks911 in forum Blu-ray RippingReplies: 4Last Post: 15th Dec 2011, 11:20 -
dvd ripping software - help!
By counterstrikedude in forum DVD RippingReplies: 8Last Post: 27th Oct 2008, 01:17 -
Best DVD ripping software
By AllanWoody in forum DVD RippingReplies: 17Last Post: 14th Aug 2008, 15:32 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22 -
questions on ripping software
By Mort439 in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 22:09
