  1. Ok I don't have problem making my dvd by having 2 separate files however, the program that will do a good menu will take only mpeg files. Any body can suggest me a way to combine m2v file and ac3 file to be an mpeg file so I can use it in auhtoring program that takes only mpeg ?
    or is there any good authoring software that let me create menu easily and take both file ?
    I used DVD maestro and It's kind of too much work to be done for a decent work.
    Thanks alot
  2. You can use TMPGEnc for .m2v + .ac3 -> .mpg.
    File menu > MPEG Tools... Simple Multiplex. Select MPEG-2 Program (VBR).
  3. Thanks a lot !
    I tried using TMEPG several days ago, it appreas that I forgot to select the fileformat as mpeg2-vbr that's why it sould not detect the file LOL
    thanks again
