Got a few problems playing an SVCD encoded in 2-pass VBR, max bitrate set to 2520kbps and audio at 128kbps. The video would freeze and distort and audio would go out of sync, etc.
I just used bitrate viewer to analyze the file, and found that the peak bitrate was over 3200kbps (including video and audio). This is far more than the 2648kbps max (video and audio) I should have gotten. I'm assuming that this is the cause of the problem.
How can I stop TMPGEnc going so far over the max bitrate? I can't use CCE, my Pentium 2 CPU isn't supported![]()
You can try encoding with lower maximum bitrate.
I always use max bitrate of 2450 to avoid such bitrate peaking problems.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48
