Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 106
  1. I was having the DVD not been recognized issue . after installing 9a it's working ok now
  2. testing it now, so far so good. Hope it looks good. Guess I'll find out soon enough :P
  3. I just installed this progam and had the same problem of not recognizing my dvd rom. This is what I did to get it to recognize it now. Go to the installation folder, C:\Program Files\Dvdbot. Then open up the DVDbot configuration settings file and edit the line that says "dvddrive=D" and change the "D" to whatever drive your dvd rom is. Restart the program and click refresh the dvd drive and that worked for me. Hope this helps.
    JCuervo811
  4. The program works really good, I can't complain. It looks just as good as the original to me, and that's what we all want isn't it? Nice little prog.
  5. I run an internal Sony DRU500a burner and a 16X CD-ROM on the Secondary IDE set to use DMA. I tried all the previously mentioned fixes, and the proggy will not recognize either drive. If the author wants to sell his product, he's going to have to provide a better beta product than this. It's rather frustrating not to be able to even use the product to evaluate it.
    Jim Petrick
  6. As DVDBot use DVDDecrypter (wich is bundled among other progs in the final exe), please use DVDDecrypter separatly and indicate what settings do you use for it to works properly 8)
    DVDBot team member
  7. jvc7845
    I use the default settings in DVD Decrypter never had to change a thing. One thing DVD Decrypter does that you dont do in your program is allow us to pick the DVD Drive using a drop down box.
  8. jvc7845
    D/L the "a" version, still can't get it to pick up my DVD Drive. I re-booted, have the DVD2One in the folder. So did I miss something? Please Advise.
    Bud
  9. Originally Posted by Bud
    jvc7845
    Bud
    you should run bot when your DVD is already in the drice. bot have diffculties when inserting dvd and detect "on the fly"
    DVDBot team member
  10. jvc7845
    There's one in the drive now and has been for the past hour, I even played it just to be sure the DVD was in order. Still can't get DVDBot to pick up the drive. The only other dive I have is a Yamaha CD-R type. I sure would like to test out this software. Thanks in advance.
    Bud
  11. Hi,
    I started a movie in PowerDVD, and then started DVDBot.
    And now the program finds the dvd-drive!
    I am testing the program right now.
  12. Made sure the Drive letter said "D", which is where my Pioneer A04 is located, restarted the comp, after restart inserted DVD and started DVDbot, still no DVD Detected. Wish I could get this program to work.
    Peace,
    Zorin
  13. Good thing the uninstall works better than the DVD detection
  14. Originally Posted by zorinsmarket
    Peace,
    Zorin
    Are u using any kinda Image drive, I did a test with four DVD drives hooked up to all channels and SCSI HD (sorry I do not have IDE HD on my Video Machine) Anyway I had a Diff. DVD in all the drives and nothing. Then I mounted an Image and it found it, so I went and uninstalled all my imaging Drives and then the only DVD to pick up was the Pri. Master, nothing on the other three, changed them all around and all the DVD's worked if they were the one on the primary Channel and Master, So just wanted to pass on my findings mabey it will help u. I will hook up a fresh system and put nothing but one HD and three DVD to see what the outcome is, Anything to help.
  15. GandyMan,
    I have no image drives installed and only one DVD writer on its own IDE channel and cable, this program should find it and show the vid, but it doesn't, don't know why, hopefully this will get fixed, cuz I really want to try it.
    Peace,
    Zorin
  16. It's funny how some progys react with different systems. I've had zero problems with DVD Bot right out of the gate, which is very unusual for me. I have 2 DVD drives, one burner and one reader. I can put a movie in either and it does just fine. Setup master/slave secondary ide. I put the origional DVD in the player a blank in the burner, press a couple buttons, bingo out pops the backup- I've been dreaming of this ever since I started backing up. Can't wait for the final version!
    The DEAD are alive again!
  17. Originally Posted by Mr. Twister
    To help us figure out why some can not get this to work, do u have two HDs and can u put the DVD Movie in the burner and it find it. Anything would help us nail this down
  18. I have 2 HDD's Primary; C:Master, Ddata) Slave. Both DMA enabled
    I have 2 DVD ROM's Secondary;AO5-Master, Creative-Slave.
    I can have DVD Bot open and insert DVD in either drive and have it detected or have a DVD in either drive and open DVD Bot and have it detected. Either way it works. I'm running W2K
    I never installed .9 only .9a (if that matters).
    I'm instructing DVD Bot to write to D: drive
  19. WHooa!
    Just for shits and giggles I unplugged one of the two DVD drives- THEN I get the non- detect in Bot. It seems to happen whichever drive I unplug. Seems it needs both drives plugged in to detect.
  20. Originally Posted by Mr. Twister
    WHooa!
    thanks for the test, it helps alot in figuring out what is wrong with some peoples system and why they can not use it.
  21. I have the same problem with it not even seeing my drives.
    Those of you that have this working...what drive letter are your DVD drives? Mine are F: and J:
    I have a theory that the program will only see a DVD drive that is the D: drive. I could be completely wrong, but I am just trying to troubleshoot this...I want to play with this program!!!
  22. It's wierd mine wasn't working, but now it works on all my drives. It even worked when I mounted an image on Daemon tools it found it.
    I have a DVD-ROM a DVD-RW and a Daemon tools drive regardless of where I put a dvd in it works even if I just mount an ISO image on daemon tools.
    Beats me.
  23. Member
    Troy, MI, USA
    Program does not like Pioneer A04 either. I have done what JCUERVO811 recommended and nothing happened. Also have DVD on drive F for at least half hour...let's givem DVDBot guys some time to fix this before we get to excited.....
    Best regards
    Regards,
    JDaCunha
  24. inthedark
    You may be on to something with drive letters mine are F & G. Still can't it it to work.
    Bud
  25. My DVd-rom is drive G and my DVD-Writer is Z and it finds the DVD's with no problem.
    Bottom line is the program is buggy and needs to be fixed.
  26. Has anyone done a tcpdump and snoop on HTTP packets to see what information is being transmitted from your machine to the net when you run DVDBot
    I'm beginning to worry
    -kwag
    KVCD.Net - Advanced Video Conversion
    http://www.kvcd.net
  27. Member
    Dec 2002
    The Great Northwest
    Hi All,
    Wow, you guy are fast I thought I had found something new and you are all over it!! Anyone else crashing when trying to select more I Want more options. I tried and windows crashes and closes program. If i just use default, the whole thing it working. But that would not be my first choice I would like to pick and chose final product output. I am doing MUMMY now at default there are a ton of extras in this one. Any Ideas on crash?? I see there appears to be a program Rep on line
    ANY HELP WITH OPTIONS CRASH?
    OOPS Looks like I will have to use alternative burn method
    Error DEVICE NOT READY??
    I'm trying to burn manually with DVD DECRYPTER seems OK.
    LOOKS LIKE TOOLS
    DVD DECRYPTER
    DVD2AVI
    DVD2one
    IMGTool
    Then what DECRYPTER AGAIN??
    Sounds like a winning combo
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  28. Originally Posted by inthedark
    NEW .91 Out lets u select your DVD Drive.
  29. Still having problems. Will not pick up on the DVD, dot think it likes the Pioneer A04 . Will have to wait for the guys to do some more testing.
    Bud
  30. Tried the new version, still no go...it doesn't even say NO DVD FOUND or anything. I changed the ini file to DRIVE:F (which is actually my A04) then i actually got the famous NO DVD FOUND message. I guess it just hates my A04! Anyone have it working with an A04? If so, what operation system, and what Firmware, and DMA or PIO?
