I've noticed that when I don't use the wizard and hit the load button at the bottom of the main TMPGEnc Window, and look at the settings of the loaded template, that they're not the same settings as within the wizard... For example, the NTSC Template settings use Full Screen (keep aspect ratio) set whereas the wizard for a NTSC VCD is at Full Screen. This leads me to believe that the template has optomized settings whereas the wizard has default settings (like noninterlace where as the template outside of the wizard has interlace). I don't understand why the keep aspect ratio and other settings found by clicking the Expert button inside the Wizard Window aren't set to the 'optomized' settings as found in the template file. Is there a way to load the template file in the wizard? If not, is there a way to choose VBR over CBR when making an SVCD and not using the wizard?
Results 1 to 1 of 1
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
MakeMKV IO settings
By leghorn in forum DVD RippingReplies: 9Last Post: 15th Jan 2011, 22:04 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 10:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 16:20 -
Help with VLC settings
By Jedi5 in forum Newbie / General discussionsReplies: 33Last Post: 9th Nov 2007, 20:25
