  1. I dl'd AC3Fix along w/the GUI and BeSweet1.04 .. what else do I need? All I see is a DOS-screen flash for a fraction of second after pressing the "Fix Audio" button in AC3Fix GUI program.. anyone?
    I'm trying to 'fix' the audio file to an extra that i re-encoded.. I'm trying t remux/re-author but Maestro won't accept the audio file.. after doing a search, I found you could resolve by running the 'corrupted' audio file thru AC3Fix.
  2. Try using AC3fix as follows:
    Open a DOS box and go to the folder in which AC3fix is located. Make sure your AC3 audio file is in the same folder. The type the following command.
    ac3fix.exe [ac3 file which needs to be fixed] [new name for ac3 file]
    eg.
    ac3fix.exe 007sound.ac3 new007sound.ac3
    good luck.
