I have converted a svcd to dvd-r using tmpgenc.....everything went fine but when i play it in my Pioneer 343 dvd player it only shows up in 2/3 of the screeen.....any clues to what might have went wrong.
thanks
It sounds as if you did not set the aspect ratio correctly
In TMPG under your Settings, then on the advanced tab there is a drop down box. If you wanted to scale the 480x480 res of the SVCD clip "up" to 720x480, you should set this to Full Frame (Keep Aspect Ratio)~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
what about if you use ifoedit.....and dvd patcher....it does the same thing
also sometimes in tmpgenc when i encode a svcd to dvd-r it gives me illegal mpg stream....any clues to what may be wrong in that.
Thanks for your first reply spidey
Pioneer DV 585a playing several new movies in wrong chapter order.
By snirpens in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th Apr 2012, 14:52 -
Pioneer DV400V - Movies stop playing
By Oxnardo in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Oct 2011, 10:00 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Pioneer DVR-220 and playing dual layer problem
By whitemtntn in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2008, 19:12 -
I am confused about the DTS playing capability of my Pioneer DV-393-S...
By oleglelchuk in forum DVD & Blu-ray PlayersReplies: 7Last Post: 18th Apr 2008, 22:34
