i'm trying to encode subs into movie file. when i open the file in virtualdub, it's not producing any sound. i check the file info and it gives then following info, in particular the audio stream:
compression: unknown (tag 2000)
do i need to install any audio codec??
sounds like a ac3 sound file. Open file in Gspot and it will tell you what codec is needed.
May the force be with you. -
ok, i opened using gspot and for the audiostream info, it says the codec used is ac3 and for the status, it says codec is installed. but for the streamtype and a/v interleave, it says the type is openDML AVI, I/L: not supported, IMRR: n.s
Webm Codec Advice Needed
By jg84 in forum Software PlayingReplies: 9Last Post: 20th Apr 2012, 19:10 -
Codec needed for particular .MOV file
By 6079 in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2010, 12:45 -
Needed : A adpcm audio codec link plssssss x
By xJensbigproblemx in forum AudioReplies: 3Last Post: 30th Jun 2010, 00:41 -
Low CPU Intensive video codec needed
By fitch.j in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 04:40 -
strange codec needed
By bountylord in forum Software PlayingReplies: 1Last Post: 8th Mar 2008, 10:40
