I had hours worth of 5min video clips (around 1gig each) and having limited hard drive space, I packed 'em up -- 9 files in each folder and compressed them using Stuffit Standard 7.01.
Now, trying to unstuff them I get an damaged file error while still decompressing the first .mov in each compressed folder. Nothing salvagable as far as I can tell.
I thought Stuffit 7 was supposed to work okay with files over 2gig?
Did I completely screw myself?
What method should be used (if any) for archival compression of DV files?
Cheers,
Bryan
DV is a compression, albiet a pretty lousy one. Just keep them as .mov. If you need smaller files, try compressing to MPEG2 or something. As far as recovery goes, I think you're boned.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I know of no other way to recover the files. Have you updated the Stuff It software? If so try to go back to the version you compressed with. As for the archival of DV mov files I'd say keep them as they are. Just burn them to disks or find a cheap hard drive to copy them to.
Yeah, I didn't think there was any possible way to recover my files... Just goes to show -- It's Best to Test!
Still can't believe I just assumed compressing them would work without testing first! Oh well, perhaps this thread will save someone else's work.
Thanks for the replies!
Bryan
Screwed over by a CODEC install
By AveEye in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2012, 05:34 -
Compression technique/standard used in MPEG2 Transport Stream
By digitalmystic in forum Video ConversionReplies: 1Last Post: 1st Nov 2010, 07:50 -
Industry-Standard For Compression / Conversion?
By zythyl in forum Newbie / General discussionsReplies: 7Last Post: 30th Aug 2009, 05:12 -
I think i may have just screwed up my pc next door....
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2009, 01:13 -
Screwed Up the Muxing
By Mnem in forum SubtitleReplies: 6Last Post: 16th Apr 2008, 16:40
