Has anyone tried this software for $36? I know there are FREE proggies out there to do this but just curious if anyone had tried it.
http://www.dvdtodivx.net/index.htm
Super DVD ripper is an easy to use DVD ripping and copying software which can copy DVD to DIVX AVI files or MPEG1 MPEG2 files. Super DVD Ripper can then copy DVD to VCD or SVCD, an ideal method to dup dvd or make backup DVD copy. No expensive DVD burner required, direct burning to CD which can be played in your DVD player!
Molasses on tranks...methinks for this site.
the web in slo-moCorned beef is now made to a higher standard than at any time in history.
who is this joker?
here is a quote from the FAQ:
5. What's DIVX?
DIVX is the MP3 for movie. You get the same video quality as DVD while keep 1/10 of the size. You can play DIVX in your computer or share it in Internet. Some newer DVD player can now play DIVX movie as well. -
Originally Posted by RabidDog
Anyone got an idea around this problem.....??
thnx
Anyone know how I can buy the "Pro" ver of Sony's DVD Architect ?
By WBFAir in forum Authoring (DVD)Replies: 3Last Post: 6th Jul 2010, 14:02 -
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 14:57 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
How can I know if DVD-RW media is CPRM compatible ver 1.1 1.2
By bill_dom in forum MediaReplies: 6Last Post: 3rd Dec 2007, 18:53 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 16:00
