I've used the Memorex brand for creating VCDs for a long time now. All of a sudden I have problems erasing them. I've tried different softwares to do this from NERO, EasyCD, and some freeware software. But they all seem to be working the same when it comes to erasing. The problem is that it leaves couple of MBs on the CD-RW, and the burning software doesn't recognize it as a blank CD, so I can't reuse it anymore.
Results 1 to 10 of 10
i dont know if it will help,try formating the disk then erase it.
not sure if nero can format,but i think it does. -
Did you overburn them? Erasing doesn't go that far.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I've tried formating them but I still have some data left, so its not completly formated
I've used the cd-rws no more than 3 times, and I always write on 4x speed, so I don't think that It is overburning problem -
A good thing to try is a different brand disc. If it works & erases flawlessly then those memorexes may be faulty - since it's a name brand they might even replace them.
Panasonic DMR-ES45VS, keep those discs a burnin' -
I had problems with my drive recognizing a pack of memorex cdr-w's. My friend's drive had the same problem with them. I returned 'em.
"Art is making something out of nothing and selling it." - Frank Zappa -
Today I tried formatting and than erasing the CD-RWs and it worked. But from now on do I have to repeat the same process. Because it takes almost an hour just to format and about 20min to erase. But I guess it's worthed.
get yourself a copy of HaCD burner
:P :P
http://www.acard.com/eng/ -
how do you reformat? I've got the same problem with my memorex CDRW's--I'm up to about 8 or 9 that won't work. They said they'd replace them, but I'm still waiting for the new ones to comeOriginally Posted by vtoskov
what are you askin' me for...
I'm an idiot! -
sorry about my late response. I havn't visited the forum for a while. You can format your CD-RW by going to the My Computer and right clik on the CD-R drive icon and ther should be option of Format. Of course the CD-RW has to be in the drive.how do you reformat? I've got the same problem with my memorex CDRW's--I'm up to about 8 or 9 that won't work. They said they'd replace them, but I'm still waiting for the new ones to come
DVD+RWs no longer play
By Iconoclast in forum MediaReplies: 31Last Post: 26th Mar 2012, 21:59 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 21:55 -
Erased -RWs no longer recognized - HELP!
By will7370 in forum Newbie / General discussionsReplies: 6Last Post: 5th May 2009, 19:08 -
DVD+RWs going bad
By lmemsm in forum MediaReplies: 18Last Post: 12th Jun 2007, 14:40 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 13:51
