I'm using a Canopus ADVC-100 via the PC's firewire port.
My problem is that, although my finished captures have sound, there's no sound whilst I'm monitoring the capture. It's the same in whatever package I use for capturing. Although it's not a major problem, I wonder if anyone has any ideas as to the cause ?
It may simply be the software/hardware spending its time capturing rather than monitoring what it's capturing for your benefit!
My Ulead Videostudio 6 produces extremely choppy sound while capturing so I simply turn it down! As you say, it's not a problem as I know the sound is being captured.
Regards
Chris -
i use windows movie maker and it doesn't have sound either, but the finished product does have sound. I just open the lcd on my dv camcorder and teh sound is played through the camera
Im getting an Error Whilst Using Windows DVD Maker
By toqi786 in forum Authoring (DVD)Replies: 1Last Post: 12th Nov 2009, 02:52 -
How to have the date and time updated whilst on the net.
By blinky88 in forum ComputerReplies: 4Last Post: 23rd Sep 2009, 12:04 -
PAL to NTSC - when do i select this option whilst editing & dvd authori
By johnnybravo in forum EditingReplies: 6Last Post: 24th Jul 2008, 10:23 -
Adding audio as background music whilst listening to the main sound
By Mrwoo1234 in forum AudioReplies: 3Last Post: 29th Dec 2007, 09:30 -
using modem router whilst shut down
By Tbag in forum ComputerReplies: 2Last Post: 28th Sep 2007, 16:14
