  1. i use dvd decryptor, dvd2avi, tmpeng2.5, vcdeasy, chapterxtractor, and nero to burn. i used the guides, but im having trouble when i try to fit the movie on one cd. i get through all the steps ok, but when i playback in a dvd, it plays fast. almost like its being fast forwarded. what am i doing wrong????
    Aug 2002
    Try using DVD2SVCD as long as your DVD player supports svcd. Its an all in one solution. You can find the software & guides at www.doom.org.
    Another way is use easydivx to rip & encode your dvd to divx avi, then use tmpgenc to convert to MPEG VCD or SVCD. Then burn using VCDEASY. Easydivx is available from www.easydivx.does.it
    Its freeware & really easy to use.
