I want to make a DVD-R from a divx file and use the Pioneer A03 drive to burn it. Will this drive do the job? Is there anything i should be aware of with this drive?
I am using thr A03 for a while an have successfully produced several DVDs with Nero (the newest version finally is working), Instant CD/DVD Version 6.4 and Ulead DVD Moviefactory (Demo available).
Depending on the framerate of the DivX-movie you first have to convert the movie picture size to a DVD-compatible format using resizing in an appropriate programme like VitualDub. 720x480 for NTSC and 720x576 for PAL. Some MPEG2-encoders also require the audio-track to be uncompressed. This can also can be done with VirtualDub.
Then the film has to be encoded with a video-bit-rate < 9.8 Mbit/secand the audio track as 48000 Hz and 192kBps. Generating the video-track as and elementary stream in the m2v-format and the audio-track seperately as a mpa-file (MPEG1-layer2-format) allows to use the freeware programme IfoEdit to author the film as DVD.
avi2mpeg, TMpegEnc or CCE can be done for encoding.
Finally the DVD-file set in a separate dirctory has to be burned with one the above mentioned burning programmes.
CU
Schmendrick
Pioneer DV-F727
By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 14:59 -
Pioneer 531H
By cscasto in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Nov 2008, 21:19 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
pioneer dv400vk
By suomiaussie in forum DVD & Blu-ray PlayersReplies: 4Last Post: 9th Sep 2007, 09:42 -
Can anyone help on this one please - Pioneer 110D
By mattiusb in forum DVD & Blu-ray WritersReplies: 30Last Post: 3rd Jul 2007, 03:37
