When encoding a movie using TMPGE2.58 can you use your computer to do other things? Or will this mess up the movie?
It won't mess up the movie at all. It may slow your computer down a bit depending on the priority you give TMPG.
Set the priority's on normal or idle if you plan on using the computer to do other things while encoding.
Hope That Helps!!!
:P
This is my first post. I'm glad someone finally asked this question. I have been wondering myself if it would mess things up. It's good to know that it won't.
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13
