  1. Hi all,
    I'm extracting episodes from several Star trek episode DVDs I have and am trying to compile a best of DVD-R. I will extract .vobs, run thru DVD2AVI then re-encode to bitrate of about 3000 with TMPGEnc, then Re-author with Maestro.
    One thing I'm wondering about is when re-encoding in TMPGEnc I want to match the exact resolution of the episodes. I have done stuff like this before but in the past the material was always 720x480.
    Anyone know of quick way to find resolution of .vob files?
    Also, I wonder if I should choose 4:3 or 1:1 in TMPGenc? Any thoughts...
    rhuala
  2. Member wulf109's Avatar
    Jul 2002
    Programs like Mpeg Properties and AVIcodec will give you that information. I believe there available in the tools section on this website.
    I can tell you from lots of prcatical expierence that thier all 720x480,both the TOS and TNG disks. You know the TOS disks are single-layer,except for disk #40.
  3. Thanks, Ill give them a try. Hope they work for .vob's. I ended up using ReMPEG2 but it took like an hour to load the stupid vob file...
    rhuala
