    May 2001
    USA
    Every tutorial I read seems to suggest either creating an image file or using Nero's DVD-Video template to burn my back-ups. Is there a reason that just burning my completed AUDIO/VIDEO_TS folders using the standard "data" mode is not a good option? I've used the latter method on about 10 burns so far (DVD-5, DVD-9s split to two disks using IfoEdit) and they seem to play well using 3 different DVD players.
    Please advise if I may have some compatibility problems down the road.
    Regards,
    Golem
  2. dont worry about it, i use prassi on a data burn.
    done well over 200 dvdr and not a problem.
    thingimijig.
  3. Another great burning program is imgtools using high compatibility mode. You can download it on doo9.net I think. My dvd player won't play dvd's burned with anything but this program, so that must mean it burns pretty compatible dvds.
    Jul 2002
    Scotland
    My standalone will only play dvd-r's burned on Nero dvd video.
    Can you explain how to use image tools.
    thanks.
    dlb.
