Bernie...Originally Posted by BernieR
You really need to trust me on the Toast thingIts not gonna work out for ya...Use Missing media Burner.
Toast *cannot* process SVCD mpeg2. It *only* works with VCD mpeg1 mpeg files.
-K
Results 91 to 104 of 104
That is because it is only 1 discOriginally Posted by BernieR
Hence 60 mins
Can I ask you something? Why not try another dvd? I really can't do anything, or determine if this is an overarching problem with us banging our head against these two titles, neither of which I have, or can get, until my town thaws out.
-K -
I think this point is getting lost on you as well. vcds and svcds, for a *full* disk, on 80min media (700mb/80min) are *800MB* not 700MB.Originally Posted by BernieR
Believe this, like you believe the sun rises in the east. I know what the CDR *says* on it, but we are burning in XA mode 2, which uses the *Time* Number, not Data mode 1, which uses the Mb number.
-K -
OK,
kinda good news here:
Going back to V1 files that were output from StarWars DVD to VCD remember you wind up with THREE .mpg files, only the first would import into toast.
Well, i just used Gumby "VCD Jelly" and check the box that says "replace header" and viola -- the new .mpg files import into toast and burn with pride (on VCD setting)
As regards to Jurassic park, i guess your right Kai, i should just give up hope. The crazy thing is that i have a 1.85 gig mpeg-2 file that i bet i will find a way to use eventually. The quality looks so good that its tough to throw it away....
Bernie -
This is BAD BAD BAD!!!! They are *not* vcds. PLEASE don't do this, you are only making *broken* disks, in the wrong format, no less. PBC won't work right, among other thingsOriginally Posted by BernieR
Then you can use MMT to split it into 800MB chunks, then use either VCD Builder (EXCELLENT commerical quality software...even does SVCD Menus) or GNU vcdtoolsX to build proper SVCD images.
Bernie
In fact VCD Builder integrates with toast by building multi-track XA images (ugh) but either way, its better than hacking the headers to force toast to do something it wasn't designed to do
You seem to really have a vested interest in toast
-K -
Originally Posted by KaiCherry
KAI!
the files i was able to get to work from Star Wars II were DVD to VCD (mpg-1) NOT SVCD!!!!!!!! They were not acceptable (#2 and #3 file) as output from forty-two version 1 into toast, but when i changed the header using Gumby they worked -- as VCD NOT SVCD!!!
So, the out put of v1 for the setting (DVD to VCD) only needed to change the header to get VCD to work!
again this is OLD news as you have already moved on to v1.5 and bin files so its moldy news .
Bernie -
Hey Dick,Originally Posted by rmassung
Output from forty-two v1.5 for Jurassic Park was as such:
in a folder named "burn this"
JURASSIC169-1.bin 805.7 mb
JURASSIC169-1.cue 4kb
in a seperate folder:
JURASSIC169-1.mpg 1.85gig
biles.mpv 1.62 gig
biles.mp2 202.6 gig
i have tried to put that bin through gumby and toast and mmb but can not get it to burn a working Svcd.
If i try to put the 1.85gig mpg file into SVCD builder in Gumby i get a unix error code.
Bernie -
AHHHH
Well for vcd its cool
People use gimby to do all KINDS of things, bordering on Satanic Ritual, lol...
Which is fine of course, if you like that sort of thing
Party On
-K -
Now i have in my mind Gumby being bent over some Satanic Ritual bench and tortured until he turns green , oh wait he IS green!
Bernie -
are you encoding as SVCD or VCD? if you are encoding as vcd just drop the bin file into toast as a video cd and burn.. .if you are burning an SVCD i dont suggest using toast at all unless u make the bin into cdrom-xa tracks using something like vcdtoolsx... i find the best way to go about burning these bin/cue files if SVCD is using cdrdao-- ross has put together a nice gui for this called missingmediaburner.Originally Posted by BernieR
homepage.mac.com/rnc
*note: if you ever have problems in cdrdao, but it *IS* recognizing your burner sometimes you need to manually edit the .cue file taking out any occurance of the line "FLAGS DCP"-- cdrdao doesn't appear to like that line too much and vcdimager will throw that in sometimes when creating bin/cueAs below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
hey guys,
I noticed the audio track in my dvd-dvd forty-two iso image is only the 2 channel track (this is isomina by the way) . Is there a way to get the 6 channel audio track (being a little picky here)?
Also the sync is severly off... weird as I did the same movie in 1.02 with no problem -
Im not trying to discredit ffmpegx. I have the most recent version installed and use it all the time for non SVCD related issues. I was just trying to emphasize how nice Forty-Two is for Direct DVD to SVCD conversion, a thing ffmpegx seem to have trouble with.Originally Posted by sherry
All of the source programs like ffmpegx and forty-two are wonderful and thier hardworking makes should be exhaulted in the Mac Hall Of Fame! -
Hello Bile,Originally Posted by bilestyle
I am trying to go DVD to Svcd. MMB doesnt seem to want to work with my cd burner so i guess i will just have to wait until you guys make a drag and drop solution that works with Toast.
Bernie
Can't Read DVD+RW with XP
By Ailanthus in forum MediaReplies: 7Last Post: 13th Nov 2010, 05:44 -
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 11:13 -
Help my drive cant read?
By mad_max911 in forum DVD & Blu-ray WritersReplies: 13Last Post: 30th Jul 2007, 12:24 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
