    Mar 2002
    canada
    does anyone know of a good program for creating animations?
    :icon10:
  2. I havent done a lot of animiations but for what i have done i used Jasac.
    windows xp pro
    AMD XP 1800
    100G harddrive
    Pioneer a03 dvd burner
    www.rogains.com for pics
  3. Member Conquest10's Avatar
    Chicago, IL
    imageready by adobe is good at animations. comes with photoshop.
    Mar 2002
    canada
    i have that,but i'm looking for something that's really easy to use and thats almost automatic. is there such a thing? i just want to make some simple animations like the emoticons.
    thanks
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    gif workshop or swish
    as mentioned -- the adobe app can do a good job also - bit more expensive though
    Mar 2002
    canada
    thanks....i think i'll give swish a shot imsim:
