I was trying to use virtualdub1.3c to convert an asf file into avi, but I got an error messages says:
"can't find decompressor for type wmv1 (unknown)"
Can anyone tell me what does it mean? and what can I do about it?
Thanks a lot!
If the ASF is a standard file, it sounds like you have a codec missing and need to install it.
If the ASF is protected, there is not a lot you can do.
Install the popular codec's, also make sure your Microcrap codec is not locked. -
I tried to install all the popular codecs, but I still get the error mentioned above. Any other suggestions?
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 16:36 -
Vorbis decompressor for virtualdub
By mkr10001 in forum AudioReplies: 2Last Post: 14th Mar 2012, 12:58 -
[solved] virtualdub + no decompressor prob...
By j6044 in forum EditingReplies: 18Last Post: 4th Sep 2010, 07:14 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2010, 23:05 -
Virtualdub Xvid Decompressor problem
By unkown in forum EditingReplies: 12Last Post: 13th Aug 2007, 19:38
