I don't know if anyone else had this problem, but I am trying to rip from a DVD using "CladDVD XP", which worked fine. the problem I am having is,
when I go to the next process, using "DVD2AVI" Instead of me ending up with two file, for Audio, and Video, I only have one file, and that is the
video file. I redid the job a few times, with the same results. Can someone
tell me what I am doing wrong? Thanks in Advance...
Sorry mate, dont know much about the software u mention. Try easydivx, its easy to & does the same job. Get it from www.easydivx.does.it . By the way its freeware!
If the audio was ripped w/claddvdxp then it should work. Did you rip all tracks(untouched) or just one? Try dvd2avi audio settings : track 1,dolbydigital decode,48->44 off. I do save project then and it creates the dv and wav files.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
