wmp 6.0 wont play divx avi's, it locks the machine. Wmp 4.1 does play them.
Is this usual or is my 6.0 corrupted. The files are all divx mpg4 v3. Also I have downloaded tons of codecs, what folder do they install to. I know where to check them but can't find the actual folder on the c drive. Finally shouldn't both my versions of wmp be using the same codecs ( this depends , I guess,
on the answer to my second question.) Thanks in advance.
Results 1 to 1 of 1
Wmp
By aaahza in forum Software PlayingReplies: 1Last Post: 23rd Feb 2011, 04:03 -
WMP changed
By KLouis22 in forum Software PlayingReplies: 5Last Post: 5th Dec 2008, 08:36 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 15:59 -
WMP
By marlo in forum AudioReplies: 0Last Post: 23rd Nov 2007, 16:50 -
wmp trouble
By ssaamm in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2007, 20:03
